newby with a question about oil...
Posted: Thu Dec 20, 2007 1:00 pm
by DOM1235
hi, not had the crf long now, but i was wondering what oil the 250 has and how much to fill etc i thought it was somting like 15 w 40 but not sure, but i think thats only the engine oil. any help much apriciated :D
Posted: Thu Dec 20, 2007 1:39 pm
by JAWS
The level for a 2005 CRF250R for the engine is 660ml's without filter change and 690ml's with filter change.
The tranny for the R is 800ml's.
The recommended oils are:
Engine - Pro Honda GN4 or HP4/HP4M
Transmission - Pro Honda HP Transmission Oil, GN4,or HP4 without molybdenum
In truth you can use almost any top quality oil. Take a look at this for some ideas of what others are using:
http://www.crfsonly.com/forum/viewtopic.php?t=13754url
It's for the 450X but you can adjust the volume for your bike.
Posted: Thu Dec 20, 2007 5:45 pm
The volume for the trans in the 2005 CRF 250R is actually 600ml after draining.
You shouldn't have any issues running 800ml, but if racing it might cause some increased resistance.
Posted: Thu Dec 20, 2007 7:36 pm
by JAWS
~ wrote:The volume for the trans in the 2005 CRF 250R is actually 600ml after draining.
First time I've know the Clymers to be wrong.
Posted: Sun Dec 23, 2007 7:42 pm
by Scott Wilson
I had read somewhere on this site that the 450x needed to use a full quart of trans fluid so that it wouldn't lock up when ridden at high speeds for long periods. I was wondering if it were the same for the 250r?
