Just wanted to get some opinions on my current situation. I have an 09 CRF250R that I have been having issues dialing in the fuel mixture.
I have had a JD Jet kit installed for about 2 seasons running great with no issues. However, This past season I got to the point where I had a serious bog under initial hit of the throttle and I found myself going all the way in on my fuel screw attempting to lean it out to acceptable level.
Today I took out the needle and it appears to have damage or wear on the needle tip.
Obviously this is a problem and I will replace the needle, but do you think this is what has caused my recent rich mixture issue?
It bogles my mind knowing it was running great and then over the span of about 4-5 races took a drastic turn for the worse. Becoming rich to the point where I had no more adjustment in my fuel screw to keep it running good, even though I had made no new adjustments or changes to the bike.
Any advice or comments would be appreciated.
Thanks, Nick
