JJ,
If you are doing the main jet, the pilot (slow) jet, and the needle... you don't need to drop the bowl on the carb!
You only need to drop the bowl if you plan to change the leak jet.
And if you
are pulling your carb all apart you should think about adding an easy adjust fuel screw and replacing the crappy stock bowl screws with stainless steel allen head cap screws to make dropping the bowl 1000% easier in the future.
For the main jet, unscrew the drain plug on the bottom of the bowl. Use a 1/4 drive ratchet with 6mm socket (I think it's 6mm) to unscrew the main.
With the main out of the way, you can get to the pilot jet which is a little north of where the main was. It's in a plastic tube, which you should be careful not to damage. You'll need an extremely short and narrow straight slot to get to it. If you don't happen to have a tiny and
short screwdriver - you'll need a right angle drive like ~ posted above. I've also had good luck with a "finger drive" with a
straight slot bit ground down to be a little narrower. It's a little hard to describe, if I can find a picture I'll post it.
Don't know why you'd be having a hard time getting to the needle. However, I can say that long blade "T" handle hex (allen) keys makes the job a lot easier. With the seat and the tank removed, you should be able to get to both cover bolts fairly easily - although you may need to loosen one side first and then rotate the carb a little to get to the other side. After the cover is off, use the appropriate size hex wrench to remove the needle bolt thingy (well, actually "screw set, jet needle"), watch out for the little spring. Then use the Honda jet removal tool to take out the jet and replace the jet or move the clip - whichever you're trying to do. You can use extra long nose needle tip pliers to remove the carb needle in a pinch, but the Honda tool is tons easier (and only costs a few bucks if you need to go out and buy one).
Long screwdriver to easily loosen the boot clamps, to rotate the carb for access.
Needle Cover on the top of the carb (pic courtesy of JD).
Remove cover (3mm allen head screw) with
long T handled ball tip hex key...
Remove the "Needle Cap" (4mm allen head screw) with hex key (pic = JD)...
Remove needle with HONDA needle tool (pic = JD)...
Replace Needle and/or adjust clip position. Reverse process to button everything up.
P.S. For changing the pilot (slow) jet, I use a "finger drive" with a straight slot bit ground down a little to make it a little narrower (the drives are from Sears, $6.99 for a set of 3 -- you can also find them other places).
Good Luck!
