Crf300l gearing
  • Viper94bite
    Crf300l gearing
    by Viper94bite » Thu Nov 18, 2021 11:54 am
    Just curious if anyone has done 13/42 on the crf300l and what your max speed is.
    More interested in cruising speed.
    Swapped to 13 tooth in front. Would like a little easier lift of front end, but hope to still maintain at least 70 ish mph.
    Re: Crf300l gearing
    by crfsonly » Thu Nov 18, 2021 8:52 pm
    Check out our CRF's Only Gearing, RPM, Speed calculator to see what gear compromises are best for your situation.
    https://www.crfsonly.com/howto/gearing/ ... ulator.php
  • Liam
    Re: Crf300l gearing
    by Liam » Thu Nov 18, 2021 10:03 pm
    I've got a similar question. Thinking about going to a 42 or even 45 rear sprocket. Wondering if anyone has done this and if so what it did to their top speed and also whether they needed to lengthen the chain .
  • Viper94bite
    Re: Crf300l gearing
    by Viper94bite » Fri Nov 19, 2021 11:50 am
    thank you for the info. didnt realize when i first looked at that you could change the bike.
    Ordered a 42 for the rear.
    Re: Crf300l gearing
    by crfsonly » Fri Nov 19, 2021 12:50 pm
    Correct! You select your CRF model/model year and press Load. It then loads all the transmission and final drive gearing data as well as the stock rear wheel/tire data. All of these parameters can be changed as well as putting in new final drive gearing to compare against. Great tool to help you decide what gearing will be the best for your situation. Glad to hear it helped!
