Welcome to the site !!
There could be a few things going on here ..... First , get rid of the Judder Spring , it will cause more slippage than it will help with a lighter clutch pull feeling ....... replace it with a regular size friction disk (same disks as the friction disks in the rest of the pack are) , you will be removing the 2 thin plates , and the thin fiber , and replacing them with the single larger friction
Next , if you are geared more for street cruising , that might be the other slipping cause , if you are geared high enough that you are constantly having to use the clutch and feather it , then you are causing heat , and heat is what is killing the clutch , also make sure you have the correct lever free play , if you do not have any , it will allow the clutch to slip .... you need some slack , so don't adjust all the slack out or you only make the issue worse
Gearing: --- Stock you are at a 14/40 , that is fine for street use , but the worse gearing you can have for any off road riding aside from open fire roads ..... you need to gear down ..... you can do this with either the front or rear sprocket , the front will equal about 3 teeth difference , the rear 1 , so if you went to a 13/40 , you would drop the ratio from 2.857 , to a 3.077 , this will help with off road , BUT , it will take away a little bit of top speed from street riding , how much I can't say , maybe a few kph/mph .... you will have to experiment to see what combo of gearing suits your specific needs , but it is always a compromise as to working good off road and working good on the road , so a smaller front sprocket (1 tooth is sufficient) or a larger rear sprocket (you can go 3 teeth larger to equal 1 tooth change on the front , but the rear gives you a lesser change with each tooth larger , so you can adjust more precisely to your needs , as opposed to the more drastic change of 1 tooth on the front which would equal 3 on the rear , and might be too much to allow you to keep good street gearing .... it is always a compromise to give you something that works better for your specific riding needs , keep in mind the larger you go on the rear , the more likely you are going to need a new/longer chain to accommodate the lower gearing .....
Hope that helped ....
