Fuel Pump Running Constantly?
  • hondooey
    by hondooey » Fri Jul 29, 2016 9:05 am
    Hi all,
    Just installed a box of goodies from crf's only including the rear tail light, led indicators, and the flasher relay.
    After I buttoned everything up, I noticed that the fuel pump was running the entire time the motor was running.
    It starts and stops several seconds after turning the key into ON but constantly runs when the motor is on.
    I don't think I noticed before but I just want to confirm this is normal operation. It would be very odd if changing the lights had anything to do with that but i've found weirder things when I get the tools out.
    Thanks!
    by Back2-2 » Fri Jul 29, 2016 9:39 am
    If the fuel pump is not running - you won't be either.
    When the key is turned on the pump is priming - Once the engine is started it runs to supply the engine with fuel. Then it shuts off at the engines point of shutting down.
  • hondooey
    by hondooey » Fri Jul 29, 2016 12:00 pm
    Ok perfect, that's what logic was telling me - thanks for the confirmation!
