'04 250x Bad Coil Resistance Question
Posted: Wed Aug 12, 2020 2:49 pm
by smokey9lives
Hi,
I'm (still) trying to diagnose a starting problem after rebuilding the carb and installing a new head and valves.
I got one "pop" out of it today which at least gives me some confidence I'm getting closer.
Question: I have 2 coils, the old OEM coil and a new aftermarket coil. Both read as having more resistance than is specified in the manual.
Primary Resistance reading is .3 ohm when it should be .07-.1 for a '04 250x.
Secondary reading is 5.8 k ohm when it should be 4.6-4.8 k ohm
Is a coil bad if it reads as having too much resistance?
Thanks
-J
Re: '04 250x Bad Coil Resistance Question
Posted: Thu Aug 13, 2020 4:50 am
Unless there is specified a temperature that the check is done at a resistance readings can be +- 10% easily.
Posted: Sat Aug 15, 2020 7:59 pm
by smokey9lives
It was definitely hotter than the 70 degF spec for testing -more like 85 deg.
Since they both tested pretty much the same I think it must be another issue, rather than the coil.
Thanks for sharing your knowledge!
best,
J
