'04 250x Bad Coil Resistance Question
  • smokey9lives
    by smokey9lives » Wed Aug 12, 2020 2:49 pm
    Hi,
    I'm (still) trying to diagnose a starting problem after rebuilding the carb and installing a new head and valves.
    I got one "pop" out of it today which at least gives me some confidence I'm getting closer.
    Question: I have 2 coils, the old OEM coil and a new aftermarket coil. Both read as having more resistance than is specified in the manual.
    Primary Resistance reading is .3 ohm when it should be .07-.1 for a '04 250x.
    Secondary reading is 5.8 k ohm when it should be 4.6-4.8 k ohm
    Is a coil bad if it reads as having too much resistance?
    Thanks
    -J
    Re: '04 250x Bad Coil Resistance Question
    by Back2-2 » Thu Aug 13, 2020 4:50 am
    Unless there is specified a temperature that the check is done at a resistance readings can be +- 10% easily.
  • smokey9lives
    by smokey9lives » Sat Aug 15, 2020 7:59 pm
    It was definitely hotter than the 70 degF spec for testing -more like 85 deg.
    Since they both tested pretty much the same I think it must be another issue, rather than the coil.
    Thanks for sharing your knowledge!
    best,
    J
