Crf250x stator issue
Posted: Sat Jun 27, 2020 8:36 am
by corey420
Hey everyone my wife's 2006 CRF250x has stopped charging the battery. I've tried 3 different batteries. The bike runs perfectly fine. Head light works fine when it's running. Tail light was eliminated. It has a new oem starter relay as the previous one failed. I put a new oem rectifier regulator as I tested the previous and it appeared to be dead. I've pulled the tank and seat off and checked over the wiring and connections. I didn't find any obvious issues. I haven't had much time to spend on it as I have to work alot. Figured I'd try asking here for some insight if someone else has had the same issue. Thanks!
Re: Crf250x stator issue
Posted: Sat Jun 27, 2020 1:55 pm
I don't have a 250X Service Manual (just Owners Manual which does not do Electrical) , the settings "should be the same though , so the easiest way to check , is remove the left side radiator shroud , right above the fuel valve , there should be (on a tab on the frame spar) a Black 4 wire plug , unplug it , and look at the Yellow wire and the White wire , put your meter to continuity test , touch a known ground (battery ground is fine) with the black probe and the red to each of the wires mentioned , and each of those wires at the connector (stator side) should have continuity , if any wire does not have continuity , then the stator is bad , that is the fastest test ....
EDIT: , I just checked the 250X Manual from manualslib.com , The Honda Service Manual covers from 04-13 , and it is the same connecter and test as the 450X , so this is out of my 450X Service Manual ... so look for this plug and it should tell you if its bad or not , I can also post other tests if needed
