Compression test
  • username
    Compression test
    by username » Fri Sep 29, 2017 5:26 pm
    Anyone know what normal psi is for 2015 250X?
    Re: Compression test
    by crfsonly » Sun Dec 03, 2017 7:35 pm
    You have to do a leak down compression test. A standard compression test will not provide accurate results. You can find this process and specs in your service manual. Most compression issues however are with the valves not the piston. Check your valve clearances first to eliminate this as the source.
    Ken
