Where does this air hose go?
  • dplantz
    by dplantz » Tue Nov 29, 2016 9:36 am
    2004 CRF250X
    Over the weekend, I pulled my tank for the first time ever, to make it easier to change out the spark plug for once.
    I found an air hose that sits right above the spark plug that I cannot figure out where it goes. I can see no connection on the tank, on the area around the head, anywhere near the carb, etc... Appears to vent out under the bike. What is/was this for?
    by Back2-2 » Tue Nov 29, 2016 10:50 am
    You may have found the formed line from the "T" to the transmission vent ?
    Fairly small diameter 1/4" or less ?
    It could also be crank cse vent line that someone removed from the head to the air box and routed it up and around the top of the valve cover ?
    Larger diameter 5/16" or so ?
    Try to follow it back and I'm sure you will see what and where is goes.
  • dplantz
    by dplantz » Tue Nov 29, 2016 11:40 am
    Its is a small rubber line that has an L bend to it and just sits above the spark plug
    by Back2-2 » Tue Nov 29, 2016 2:54 pm
    Just guessing but that sounds like the trans vent tube.
  • Leardriver
    by Leardriver » Wed Nov 30, 2016 2:23 am
    Does it plug in to the top rear of the cam cover?
    I've never changed the spark plug on any of the 15 CRF's that I have owned. They last forever.
