Did what i suggested with the cable fix the issue or did you find something else wrong ??
As for the valve shims
It depends on how the seats were cut , if they cut deep to rid any major issues , then the shim would be smaller , when the seats are worn down enough they need replacing , when its replaced (hopefully by someone that knows what they are doing) , then they can get the surface up higher where its supposed to be , which will give you the ability to use a larger shim
The deeper the seat is cut the closer the valve stem is to the bucket , so the shim becomes smaller (same way when the valve itself gets worn , the gap becomes smaller to the bucket , the ONLY way to remedy this is to replace the seats to , so to speak , "Start From Fresh" , or to replace the head with a new one (you can get bare heads or complete with valves/springs)
PM Ken (link below) the owner of this site , since he does this work daily in his shop , he can give you a more detailed answer and suggest what needs to be done to "correctly" remedy it (most likely by replacing seats on the next valve job)
http://www.crfsonly.com/forum/profile.p ... rofile&u=3
