2013 CRF250X Announced
    by crfsonly » Mon Nov 12, 2012 11:03 am
    Honda Pres Release - 2013 CRF250X
    CRF250X: Striking The Ideal Balance
    Honda's CRF250X stands tall as the machine that delivers a just-right balance of light weight, exemplary handling and tractable four-stroke power. Thanks to its handy size and weight and delightfully agile handling, this thoroughly capable off-road mount flat-out sets the standard for 250-class performance among off-road mounts. Whether you're into off-road competition or you just enjoy leisurely explorations through the woods, the CRF250X is a great companion to have along for the ride. Available in Red. Price: $7,410. Availability: March 2013.
    http://powersports.honda.com/2013/crf250x.aspx
    2013 CRF250X SPECIFICATIONS
    ©2013 American Honda Motor Co., Inc. - Motorcycle Division
    ENGINE
    Engine Type 249cc liquid-cooled single-cylinder four-stroke
    Bore and Stroke 78mm x 52.2mm
    Induction Keihin® 37mm flat-slide carburetor with Throttle Position Sensor (TPS)
    Ignition CD with electronic advance and lighting coil
    Compression Ratio 12.9:1
    Valve Train Unicam®, four-valve; 31mm intake valve, 26mm exhaust valve
    Starting Electric and Kick
    DRIVE TRAIN
    Transmission Wide-ratio five-speed
    Final Drive #520 T-ring-sealed chain; 13T/49T
    CHASSIS / SUSPENSION / BRAKES
    Front Suspension 47mm inverted Showa® cartridge fork with 16-position rebound- and 16-position
    compression-damping adjustability; 12.4 inches travel
    Rear Suspension Pro-Link® Showa single shock with spring-preload, 17-position rebound-damping
    adjustability, and compression-damping adjustment separated into low-speed (13 positions )and high-speed (3.5 turns); 12.4 inches travel
    Front Brake Single 240mm disc with twin-piston caliper
    Rear Brake Single 240mm disc
    Front Tire 80/100-21
    Rear Tire 100/100-18
    DIMENSIONS
    Rake 27.54° (Caster Angle)
    Trail 118mm (4.7 inches)
    Wheelbase 58.3 inches
    Seat Height 37.7 inches
    Curb Weight 253 pounds (Includes all standard equipment, required fluids and a full tank of fuel—ready to ride)
    Fuel Capacity 1.9 gallons
    Ground Clearance 13.6 inches
    OTHER
    Model ID CRF250X
    Emissions Meets current California Air Resource Board (CARB) and EPA off-road emissions standards.
    Available Color Red
    juju
    by juju » Sat Nov 17, 2012 6:45 am
    What is new for the 2013..Any changes that differ from the 2012?
    by crfsonly » Sat Nov 17, 2012 7:05 am
    No changes for the 2013 except the possibility of BNG.
  • therooster70
    Noticed something Ken
    by therooster70 » Sat Nov 24, 2012 1:53 pm
    Compairing the two models on hondas site there is a sproket ratio difference. 2012 is a 13/49 and the 13 is a 14/54. Doesn't match up what you posted so I wonder if its a late change. Matt
    Matt
    juju
    Re: Noticed something Ken
    by juju » Sat Nov 24, 2012 3:25 pm
    therooster70 wrote:Compairing the two models on hondas site there is a sproket ratio difference. 2012 is a 13/49 and the 13 is a 14/54. Doesn't match up what you posted so I wonder if its a late change. Matt
    I think that was a typo for the 2012...
    My 2012 came with 14/54 and so did others that I know of but I dropped my front down to a 13 which I think is a lot better in the woods..Im betting that the 2013 comes with 14/54 also as stated. Kinda :oops: to ask, but whats BNG?
    by crfsonly » Sat Nov 24, 2012 5:25 pm
    BNG -> Bold New Graphics. ;)
    juju
    by juju » Sat Nov 24, 2012 8:12 pm
    crfsonly wrote:BNG -> Bold New Graphics. ;)
    Lol..That wasn't as painfull as I thought it was going to be. Thanks! \:D/
    by crfsonly » Sat Nov 24, 2012 10:43 pm
