by crfsonly » Mon Apr 09, 2007 6:59 pm
DRC LED Light:
First the hydraulic brake switch works by completing a circuit to add more juice to the tail light so that it gets brighter.
Also, cut the green and black wires about 3" before the harness, so that I could unplug the light if needed.
That said, hears how it's hooked up.
1. Black wire(power) from the bike to yellow wire from DRC and one lead of the hydraulic switch.
The above connections are to give the tail light power and to provide power for the brake light that will work when the circuit is completed by depressing the rear brake.
2. The red wire from the DRC to the other lead from the brake switch.
3. The green wire from the bike to the black wire from the DRC. This will ground everything.
DRC indicates using the red wire as the running light and the yellow as the brake. However, it doesn't work properly when used in this configuration.
Hope this helps....Ken
