idling problem
Posted: Fri Mar 02, 2007 9:26 am
by aljeann
hi guys,
just installed my JD jettings. my crf250x 2006 now has a little bog than the stock jettings. my problem now after installing the JD jettings is when i rev the bike quicky and quickly release the trotlle my idle goes very slow to normal idling it takes about 2secs before it gets the right idle. have i done anything wrong?
sealevel to 4000ft
18-35.C
main jet 158
pilot jet 42
fuel screw set 1.5 turns
needle red in 5th position
no ccc modification just removed my stock muffler baffle
Posted: Fri Mar 02, 2007 10:26 am
by Halen
Have you done the air box mod yet?
Try adjusting the fuel screw by 1/4 turns until you reach a max 2 1/2.
Did you adjust the throttle idle? (screw beside carb)
Does the throttle carb feel smooth or restrictive in any way?
Van.
Posted: Fri Mar 02, 2007 4:42 pm
by JAWS
That "hanging idle" is indicative of a lean condition. Do as Halen suggests with the fuel screw to start. Did you follow JD's settings exactly? What are set at now?
Posted: Fri Mar 02, 2007 5:21 pm
definitely sounds like a lean pilot circuit. you may be able to adjust the fuel screw to fix this as recommended...if it doesn't fix the problem you can go up one on the pilot jet and it should eliminate this condition.
Posted: Fri Mar 02, 2007 9:27 pm
by aljeann
fgbf
Posted: Fri Mar 02, 2007 9:28 pm
by aljeann
hi guys,
no ccc mods dont want to open the airbox . all i want is to replace my stock muffler with yoshimura trc. yes i follow the JD Jettings instruction. 158 main, red needle 5th position , 1.5 fuel screw and i also put a 42 pilot.
stock main jet 130
stock pilot jet 40
stock needle
Posted: Fri Mar 02, 2007 9:51 pm
Try This:
open the door to the airbox. Run the bike with the door open. See if the condition still exists.
If yes, open the fuel screw to two turns.
Posted: Sun Mar 04, 2007 7:52 am
by Halen
Isn't doing the jets without doing the airbox mod a little like making a grilled cheese sandwich without the cheese?
I was under the assumption that JD was selling a 'system' in which all the modifications should be done to produce the desired results. My FMF pipe also indicated that the air box should be open and the jets are to be re-done. Just a heads up...
Van.
Posted: Sun Mar 04, 2007 8:33 am
Halen wrote:Isn't doing the jets without doing the airbox mod a little like making a grilled cheese sandwich without the cheese?
Van.
100% correct.
His recommendations are based on the airbox mod. Without the increased airflow, all the numbers are skewed.
If the air intake is left stock, you might as well save your money and leave the jetting and exhaust stock as well.
Posted: Mon Mar 05, 2007 8:47 pm
by JJ
I'm with you there, and that's why I ran with this setup. I found it in a dirtrider magazine.
I have recently completed this setup in my bike
132 Main
45 Slow
Replace needle with NCVQ (450R)
Needle position 3rd from top
Fuel screw 2-1/4 turns out.
I finally rode with this setup last weekend, and the I'm almost happy. It still has a slight bog, but nothing like before. It pulls the front wheel up now which it couldn't do before, because the bike was bogging so bad.
All the people that replied are very knowledable, and know there stuff, but if you're not down with cutting up your bike then you have to try something else like I did.
Posted: Tue Mar 06, 2007 1:40 pm
by NCLR1
I can see why your bike would come off the line harder than before since you beefed up the pilot circuit. But, I would be interested to see what the roll on is like since you are running a 132 main. But, that is hard to figure out if you are not running one with the 158 or 160 and then yours.
Posted: Tue Mar 06, 2007 2:12 pm
by Halen
JJ,
I would love for you to see what a truly modified bike runs like... The mods the article suggested are only the tip of the ice berg... what awaits underneath is 90% more power with a full modification. jmho.
later...
Van.
Posted: Tue Mar 06, 2007 9:25 pm
by JJ
Van, you've almost convinced me to do the mod's. Oh yeah, I haven't see the screws yet, did you get a chance to send them?
JJ
Posted: Wed Mar 07, 2007 11:19 am
by Halen
Sorry bro, after 4 weeks in the mail they were returned due to the wrong postage. I have resent them with the proper amount so you should get them soon... do the air box... do the air box... do the air box.
Posted: Wed Mar 07, 2007 11:21 am
I'm hearing voices again...anyone else hear that??? :lol:
