Another Rekluse question
    Cliff
    by Cliff » Sun Feb 04, 2007 7:36 am
    My mechanic used a small 'jumper cable' to allow the bike to start without pulling in the clutch. Isn't there a way to accomplish this without using a jumper cable?
    Thanks
    Oh, the jumper cable actually shorted to the handlebar, caused a spark, and now my electric start does not work anymore. Is there a fuse that I may have blown? If so, where is the darn thing?
    Thanks
    by crfsonly » Sun Feb 04, 2007 6:37 pm
    you could always get the perch adjuster which would allow you to use the stock perch and clutch giving you back the clutch switch. or you can install a bar mounted switch.
  • matt watt
    by matt watt » Sun Feb 04, 2007 9:04 pm
    There is a fuse in the starter relay holder under the right side panel.
    04 CRF250X
    Cliff
    by Cliff » Sun Feb 04, 2007 9:08 pm
    crfsonly wrote:you could always get the perch adjuster which would allow you to use the stock perch and clutch giving you back the clutch switch. or you can install a bar mounted switch.
    Hi Ken
    I have the perch adjuster, but I do not see anywhere on it where you can use it to 'close' the starter switch circuit to allow me to use the electric clutch.
    Cliff
    by Cliff » Sun Feb 04, 2007 9:10 pm
    matt watt wrote:There is a fuse in the starter relay holder under the right side panel.
    Hi Matt,
    I found it, but the fuse was good. My battery is good (tested with voltmeter), my battery connections are clean, my kill switch is NOT bad, but I cannot get the engine to turn over using the electric starter (the bypass electrical switch is jumped to complete/close the circuit).
    Ahh, this stinks!!
    by crfsonly » Sun Feb 04, 2007 9:20 pm
    i guess i don't understand why your mechanic would put a jumper so you don't have to pull in the clutch. i assumed that this was because you didn't have the perch adjuster so you removed the clutch perch.
