Quickshot Accelerator Cover
  • NorCalCRF250x
    by NorCalCRF250x » Wed Jan 31, 2007 9:30 pm
    So whats the difference with that boysen quickshot cover? Its just a cover so what did they change the size of it or something?
    2006 CRF250x
    White Brothers E2 Exhaust
    Works Connection Radiator Braces
    04 crf450
    by 04 crf450 » Thu Feb 01, 2007 7:00 am
    all it does is accelerates the fuel flow in your carb which gives you better throttle response.
    23 YZ250X
    23 FX450
    23 Tracer 9 GT
    2 990 ADV's
    15 CRF150F
    .......probably 12 others currently
  • NorCalCRF250x
    by NorCalCRF250x » Thu Feb 01, 2007 8:06 pm
    How does it do that though whats so special about the design of the bowl for the boysen one compared to the standard honda one.
    2006 CRF250x
    by Asmith » Thu Feb 01, 2007 8:29 pm
    NorCalCRF250x wrote:How does it do that though whats so special about the design of the bowl for the boysen one compared to the standard honda one.
    The AP cover forms a reservoir for the AP to squirt fuel into the engine. The Boyesen has larger channels so that the reservoir refills faster than stock.
    When pumping the throttle like a two stroke, the stock cover can actually run out of fuel on successive throttle twists. This can cause the engine to stumble or bog.
    If you don't pump the throttle like a two stroke, you probably wouldn't notice the benefits of the Boyesen cover.
  • NorCalCRF250x
    by NorCalCRF250x » Thu Feb 01, 2007 8:30 pm
    gotcha thanks agent
    2006 CRF250x
