by JimmyPwadd » Fri Jan 19, 2007 2:28 pm
It is tight but if you take off the side panel and I believe there is a wire holder keeping it in place, there is plenty of room and slack in the wiring harness to pull out the connector and make the swap. If you need more access or need to see better you can take the seat off too.
2006 CRF250X
Boyesen Quick Shot /AP mod
