06 250x looking for easy mods
  • keithb
    by keithb » Tue Jan 02, 2007 3:29 pm
    I bought an 06 crf250x and it is totaly stock, any suggestions on the cheapest and easiest mods I can do that will help me get a little more response?
    by Asmith » Tue Jan 02, 2007 3:45 pm
    Open up the AirBox, Change filter to Twin Air Power Flow(flame resistant), Remove backfire screen, Rejet with JD Jetting Kit, Replace pilot jet with # 42, Do AP mod with O-Ring, Replace fuel screw with CRF'sOnly fuel screw, Modify exhaust baffle by cutting off one disc and drilling 1/2" hole in remaining disc.
    It'll feel like a new bike.
  • keithb
    by keithb » Tue Jan 02, 2007 4:08 pm
    What is the AP mod with O-Ring?
    by Asmith » Tue Jan 02, 2007 4:17 pm
    keithb wrote:What is the AP mod with O-Ring?
    The JD jetting kit will come with two O-Rings. They are used to modify the Accelerator Pump on the carb by eliminating lag time between the throw arms. Eliminates the off idle bog that some experience when snapping the throttle quickly.
    JimmyPwadd
    by JimmyPwadd » Tue Jan 02, 2007 7:06 pm
    When it comes to spending my hard earned $$$, I am a tightwad. The very first thing I did was remove the snorkel and open the top of the air box. http://www.rickramsey.net/CRF250Xmymods.htm#airbox
    The second thing I did was cut the plugs off of the baffle inside the spark arrestor to get my X breathing better. http://www.rickramsey.net/CRF250Xmymods.htm#diffuser I then pulled the pink wire (behind the battery on the left hand side) http://www.rickramsey.net/CRF250Xlg/PinkWire1.jpg from its stock location and reinserted it in the "blank" position below it in the harness. I don't if this mod did much but every bit helps! http://www.rickramsey.net/CRF250Xlg/TheWrench.jpg
    Then I opened the air/fuel srew mix up a bit., getting your bike breathing better leans out you air fuel mix. ( I highly reccomend aCRFs Only mix screw!) All of this was FREE!
    I then went to spending so money. Some people just re-jet and drop the clip on the needle down one position which would be the cheaper way to go. BUT I think the JD kit was $70 well spent. When I bought my 250X I was rather disappointed with the ooompf, the bog and the holeshot. At the same time I installed a Boyesen Quick Shot and tethered the AP linkage together. (since I had the carb in my hot little hands) These made my X a TOTALLY different machine for around $130.
    That's my story...........so far! :)
    2006 CRF250X
    Boyesen Quick Shot /AP mod
  • PhilM
    by PhilM » Mon Jan 08, 2007 3:42 pm
    Did opening the exhaust baffle make it louder?? If so, by how much.
    Thanks
    crf~rob
    by crf~rob » Mon Jan 08, 2007 4:07 pm
    Has anyone tried the little 1" circular filtered air vents? I believe they come in a pack of six.
    Are they any good? How much air do they produce? I was curious if this is a alternative to cutting the top of the airbox up?
    thx
    crf~rob <Cali>
    06 CRF250X
    04 CRF50F
    03 CRF230F
    06 Pit Bike
  • keithb
    by keithb » Sat Feb 10, 2007 7:11 am
    ok, I installed the jd jet kit. 158 main, red needle in the 5th position, ap mod with the heavy o ring, opened the airbox and drilled a 1/2 inch hole in the diffuser. I bought a #42 pilot jet from a local dealer and it was for the wrong carb. How important is changing this pilot jet? (I am not looking forward to ever going into this carb again, wow what tight fit) is this richer or leaner than stock? also I have left the stock filter on, can I use the stock filter and still cut out the backfire screen?
    by Asmith » Sat Feb 10, 2007 7:20 am
    keithb wrote:ok, I installed the jd jet kit. 158 main, red needle in the 5th position, ap mod with the heavy o ring, opened the airbox and drilled a 1/2 inch hole in the diffuser. I bought a #42 pilot jet from a local dealer and it was for the wrong carb. How important is changing this pilot jet? (I am not looking forward to ever going into this carb again, wow what tight fit) is this richer or leaner than stock? also I have left the stock filter on, can I use the stock filter and still cut out the backfire screen?
    The pilot on the 250X is important. The bike will have some off idle bog that will be hard to correct with the stock 40 in there. The 42 makes it slight richer than stock. Easy to start, no bog, warms up faster, but runs cooler.
    The stock filter shouldn't be used without the backfire screen. Switch to a twin Air flame retardant filter when you can and remove the backfire screen. BTW this will make the least amount of difference in all that you've done, but every little bit helps.
  • keithb
    by keithb » Sat Feb 10, 2007 7:28 am
    stock is 40? I could have sworn it had a "55" printed on it. was I looking at the wrong jet?
    by Asmith » Sat Feb 10, 2007 7:33 am
    The "55" is most likely the leak jet. Is it next to the main jet "up" in the carb? Or is it in the bottom of the float bowl?
  • keithb
    by keithb » Sat Feb 10, 2007 7:36 am
    in the bottom of the float bowl.
    by Asmith » Sat Feb 10, 2007 7:41 am
    keithb wrote:in the bottom of the float bowl.
    That is the leak jet. The 55 is fine.
    The pilot you have is most likely the correct one. The pilot is directly forward of the Main jet. You would use a thin, flat blade screwdriver to remove.
    The fuelscrew ties into the pilot jet circuit, and controls it. The fuelscrew is on the front of the carb bottom.
  • keithb
    by keithb » Sat Feb 10, 2007 7:45 am
    can you get to the the pilot jet through the main jet access or do you have to temove the bowl?
    (thank you for all of your help!)
    by Asmith » Sat Feb 10, 2007 7:54 am
    keithb wrote:can you get to the the pilot jet through the main jet access or do you have to temove the bowl?
    You can get it from the 17mm plug on the bottom.
    (remember Japanese hands are much smaller)
    It is slightly recessed, use a thin screwdriver so you don't break the casting.
