Welcome To The NEW CRF150R
    by crfsonly » Thu Sep 07, 2006 6:06 am
    The long rumored Honda water-cooled CRF150R has finally left the imagination of photoshoppers and has become a reality. Honda introduces two versions of their new water-cooled CRF150R. It will be available in both a standard and Expert model. Suggested retail is $4,199 and $4,299 respectively.
    Here's the details from Honda on the Expert Version:
    ENGINE
    * Engine Type: 149cc liquid-cooled single-cylinder four stroke
    * Bore and Stroke: 66mm x 43.7mm
    * Compression Ratio: 11.7:1
    * Valve Train: SOHC; four-valve
    * Carburetion: Keihin 32mm flat slide with throttle position sensor (TPS)
    * Ignition: Solid-state CD with electronic advance
    DRIVE TRAIN
    * Transmission: Close-ratio five speed
    * Final Drive: #420 chain; 15T/56T
    CHASSIS / SUSPENSION / BRAKES
    * Front Suspension: 37mm fully adjustable leading-axle inverted Showa cartridge fork; 10.8 inches travel
    * Rear Suspension: Pro-Link fully adjustable Showa single shock; 11.5 inches travel / 10.8
    * Front Brake: Single 220mm disc
    * Rear Brake: Single 190mm disc
    * Front Tire: 70/100-19
    * Rear Tire: 90/100-16
    DIMENSIONS
    * Rake: 27°48'
    * Trail: 96mm (3.85 inches)
    * Wheelbase: 50.6 inches
    * Seat Height: 34.1 inches
    * Ground Clearance: 13.2 inches
    * Dry Weight: 169.7 pounds
    * Fuel Capacity: 1.14 gallons
    OTHER
    * Available Colors Red
    * Model ID CRF150RB
    FACTORY WARRANTY INFORMATION
    * 6 months; Transferable, limited warranty
    ncj01
    by ncj01 » Thu Sep 07, 2006 6:32 am
    wow, love it....
    hope it's valves are decent...
    my son will need one of those here in about next spring...
    by crfsonly » Thu Sep 07, 2006 6:51 am
    on the valves...racerX is saying it is a four-valve valvetrain yet honda's website clearly states the Expert version has two valves. i'll go with honda's website for now.
    ncj01
    by ncj01 » Thu Sep 07, 2006 8:17 am
    I also heard that they are using steel valves in it...excellent...
    if the valves are strong, then the only concern i'd have putting my son on one would be how easy/hard it is to start...
    acjjkamp
    by acjjkamp » Thu Sep 07, 2006 8:30 am
    the way my boy is advancing....looks good.
    red or green sticker? more than likely red. :(
    Al
    '06 CRF450X
    '05 CR125R
    and one blue...
    '94 YZ250
  • Reddog88
    by Reddog88 » Thu Sep 07, 2006 8:37 am
    Sweet!! finally a bike I might be able to get my GF on...On the valves, the honda web site says the CRF150R has the Unicam 4-valve head, and the Expert version is the "Same bike, but with bigger wheels, a slightly higher seat and longer swingarm designed to accommodate taller young riders" no mention of valves, so i"m willing to bet the 2-valve in the specs is a typo. but then again it could be a typo on the description of the 150R regular also....
    by crfsonly » Thu Sep 07, 2006 10:09 am
    my guess is it's a 4 valve configuration since it's a unicam trademarked bike. i'm going with this until i hear otherwise.
    yes, stainless steel valves is a good thing. i'm stoked about this new crf. should really shake things up in the mini class...if the AMA increases the 4-stroke displacement rule to allow it.
    Brennan82
    by Brennan82 » Thu Sep 07, 2006 10:11 am
    How do you think the matience will be on the bike?
    by crfsonly » Thu Sep 07, 2006 10:19 am
    my guess is similar to current water-cooled crfs. clean oil, clean air filter, valves in spec, run the heck out of it.
    by Asmith » Thu Sep 07, 2006 12:45 pm
  • TWISTED
    by TWISTED » Thu Sep 07, 2006 12:55 pm
    This new bike is so hot! You have to wonder what took them so long.
    Here's a link to the RacerX write up.
    http://www.racerxill.com/articles/detail/1059/the-2007-honda-crf150r.aspx
    Hmmm,am I too short for my CRF 250r?
  • TWISTED
    by TWISTED » Thu Sep 07, 2006 1:04 pm
    That was a cool video, but why did they have that crappy song playing over the sound of the new CRF 150r motor? I would love to have been able to hear that new motor ripping around the track.
    zc1
    by zc1 » Thu Sep 07, 2006 2:32 pm
    It looks like a blast. We'll definitely have to take a gander at one when they show up here.
    '04 CRF250X
  • sp1tekiller
    by sp1tekiller » Thu Sep 07, 2006 2:32 pm
    Makes me wish I was about a foot shorter and 100 lbs less....
  • TWISTED
    by TWISTED » Thu Sep 07, 2006 2:47 pm
    I'm surprised that none of the chinese companies who make rippin' 125 or 140cc CRF 50 knock-off pit bikes have taken the next logical step and used 17" and 14" wheels with an 85cc bike size lay-out. I've seen first hand some really fast cheap pit bikes. A guy last week had a cool bike that looked like he had dumped $$$ into, but claimed that he bought it like that for $1,800. He was a big heavy guy, and the bike sounded "mean" as it tore him around the arenacross track.
