2013 crf150rb problems
  • aaden150
    by aaden150 » Thu May 11, 2023 6:43 pm
    hey so my 2013 crf150rb has been having sputtering problems and hanging idle i have cleaned the carb rejetted it with a 40 pilot 145 main i did the valve clearances and put them all in spec i bought an aftermarket air/fuel screw for the carb because the stock one would vibrate out of place and fall out i have messed with the fuel screw and still have sputtering and hanging idle i checked the throttle cable and it snaps back perfectly i don’t know what else to do to fix these problems i would appreciate if someone can give me some tips or help on what i should do thank you.
  • bweighmaster
    Re: 2013 crf150rb problems
    by bweighmaster » Fri Jul 21, 2023 12:32 pm
    Look for a vaccumn leak around carbs .. spray a little carb cleaner around it to see if it stumbles , or picks up ...Usually around boot connections or intake pipe ...
