Honda CRF 150R issue, need help
Posted: Sun Jan 28, 2018 2:15 pm
by Xain
We have changed all of the parts that could have been an issue with it running for a few minutes, then cutting out, and its still doing the same thing. we've tried changing the jets, and that hasn't changed anything. We have no clue what else it could be, we checked and replaced everything you could think of.
Re: Honda CRF 150R issue, need help
Posted: Sun Jan 28, 2018 10:13 pm
Have you ruled out an ignition problem?
Posted: Mon Jan 29, 2018 6:21 am
by Xain
It runs well for a minute, and then starts to cut out, we've tried changing the jets as well and it changes nothing.
Edit:We had already replaced everything we could, including the ignition as the previous post says.
Posted: Tue Jan 30, 2018 1:33 am
Does this happen idling or when moving?
How does it idle?
What jetting do you have and is your aircleaner clean?
Where is the fuel screw set?
How does it run with the fuel cap off.
It sounds like either the fuel is not geting to the carb or electric issue.
What ignition parts did you replace?
Does it restart again straight away after it stops?
A lot of questions I know but trying to get to know your bike.
Is this a new problem or has it been this way since you had the bike.
