Losing Crank Case Oil Seal question
  • squanchwise
    by squanchwise » Tue Jan 31, 2012 7:24 pm
    New Member and didn't see the topic for 150r....
    Losing 1/3 to 1/2 Crank oil in hour of run time. It appears that it is moving to Trans oil and then out vent line. I had been advised that the right side crank seal is culprit. So couple of questions for the Docs...?
    1. Why is left crank seal not a contributor to the issue ? If it is, can it be replaced without a split case ?
    2. Is the balancer shaft seal a possible issue on left side ?
    3. If I missed the boat completely in diagnosis, please advise...
    Thanks !!
