MOJO RACING wrote:Sick of messing with jetting, I decided to check valve clearance since the bike is new with just a vew hours on it i was curious if it was still within specs which it was. It was what I found during disassembly that raised an eyebrow. The sparkplug gap was waaaaay small. So small that it looked like perhaps this ""awesome performance mechanic" that put in the hc piston and did the carb work had perhaps dropped it and smashed the electrodes or something. I even wondered if the piston had hit it but I really doubt that. I opened the gap back up to spec and made a couple more jetting changes. Hopefully I have it now. Seems smoother on the stand but I can only tell when being ridden if the breaking up is gone. Let you know tomorrow! Here is where I'm at now:
Year: 2009
Elevation: 800 illinois
Temperature Range: 50 -60 currently
Backfire Screen: yes
Air Filter: stk
Pilot Jet: 38
Main Jet: 140
Needle: stk
Needle Clip Position: 5
Fuel Screw Type: stk
Fuel Screw Setting: 2.5
AP Modified: wired
Leak Jet: stk
AP Cover: stk
Exhaust Type: stk
Exhaust Modified:stk
