The bike is pretty much dialed in. New piston and rings. All valves and valve seats checked and replaced. Only 7hrs on since rebuild. Runs flawless.
But for some strange reason I can't get 500 rpms extra to stay steady. The bike per the manual says 2000 -2100 rpm for idle and no matter what slow jet I use it stays below 1500rpm. If I increase the idle screw it goes over and the idle hangs. If I adjust idle lower it goes it goes from 1150 - 1500rpm.
I have tried every slow jet from 40-52. Currently using a 48. Adjusting the fuel screw has some effect but will not get it spot on. Too much tampering with the fuel screw causes throttle response issues.
I pulled in the hot start lever ever so slightly while idleing the bike to lean out the idle mix and the rpms went up!!!! I could even get to the 2100 rpms steady. This got me thinking that I have the correct slow jet for starting but the "slow air jet" may be a bit too small.
I figured i was too rich for idle so I went down in slow jet size. If I go too low the bike has issues starting and runs lean. Too high a slow jet and starting issues again.
I want to try using a slightly larger slow air jet or a adjustable slow air screw for this carb. If i can slightly lean out the idle fuel mixture using the 48 slow jet i believe i will get a higher idle rpm's higher and steady .
Does anyone have any experience with a adjustable slow air screw for this FCR carb. What else am I missing? Below are my current jetting info and temps.
Year: 2007
Elevation: sea level -200'
Temperature Range: current 65
Backfire Screen: yes
Air Filter: twin air
Pilot Jet: 48
Main Jet:140
Needle: jd red
Needle Clip Position:5th from top
Fuel Screw Type: flex screw
Fuel Screw Setting: 2.25
AP Modified: yes
Leak Jet: 60
AP Cover: QS2
Exhaust Type: stock
Exhaust Modified: fmf powercore 4
