what happened
    150 man
    what happened
    by 150 man » Thu May 20, 2010 5:24 pm
    so i cleaned my bike today and i rode it while the engine was a little wet and it died.i couldnt get it started again.i put a rag in the tail pipe so i didnt get water in the pipe so i dont know what happend
    motosicko
    by motosicko » Thu May 20, 2010 6:37 pm
    You got your air filter wet and sucked water into your top end and possibly fouled a plug if you're lucky. If you're unlucky you may have sucked enough water in to water lock the piston and I've seen where someone bent a valve in the process. That would be worse case.
    "There are old racers
    and there are bold racers,
    by Aussiecrf230 » Fri May 21, 2010 12:29 am
    Or you have water in your float bowl and now your jets.
    Pull plug and drain fuel from float bowl and see if there is any water in it.
