NOISE COMING FROM ?????
  • VALVE99
    by VALVE99 » Mon Aug 13, 2007 11:52 am
    JUST BOUGHT MY SON A 2008 150RB WENT TO THE TRACK TO GET THIS THING " TUNED IN " BIKE RUNS GOOD, MADE THE SWITCH FROM A 2 STROKE, ANYWAY,
    RAN A FEW LAPS STARTED HEARING A NOISE THAT SOUNDS KINDA LIKE THE BRAKES SQUEELING , ON -OFF-ON-OFF.BROUGHT IT BACK IN PUT IT ON A STAND SPUN THE BACK WHEEL NO NOISE , LUBED THE CHAIN ,RAN ABOUT A HALF A LAP NOISE CAME BACK YOU CAN HEAR IT THE MOST WHEN HE HITS A JUMP AND IS IN THE AIR SOUND LIKE ITS COMING FROM THE CHAIN SIDE OF THE BIKE [ I KNOW ITS HARD TO FIGURE OUT UNLESS YOUR THERE TO LISTEN TO IT ] JUST WANDERING IF ANYBODY HAS EXPERENCED THIS PROBLEM, JUST HAVEN'T HAD TIME AT HOME TO TROUBLESHOOT THIS YET TRYING TO GET SUGGESTIONS BEFORE I START . CHAIN GUIDE? CASE SAVER? ANYBODY?
    Aspired
    by Aspired » Fri Aug 24, 2007 3:40 pm
    It is once again a caps lock issue (3rd today actually) - your caps lock is stuck on and will need to be depressed to eliviate the yelling at people issue.
    Then we can assist you with the bike noises! Unfortunately if you can't figure out the caps lock issue then your not going to be able to figure out the bike noise issue.
    First things first.
    The best suggestion - Make sure you have a manual!
  • VALVE99
    by VALVE99 » Mon Aug 27, 2007 8:58 am
    For those of you that read the posting and didn't care if it was in all capitol letters!! I stated that I hadn't had the time to check out the noise but I did shortly after posting and it was the case saver, it did not have enough clearance for the chain , simple fix, take it off grind it down a little and it's good to go!
    gal8x
    by gal8x » Mon Aug 27, 2007 8:43 pm
    Welcome to the site. :)
    Nice when the fix is simple.
    8)
    2005 CRF450X (plated)
