Suspension Database
    Suspension Database
    by crfsonly » Thu Apr 12, 2007 6:31 am
    Please keep other info out of this thread. Only answer the questions. Copy and paste to keep format uniform.
    Note: Clicker adjustment should be expressed in clicks from full hard.
    Year:
    Rider Weight:
    Rider Weight with Gear:
    Riding Style (i.e. Desert, MX):
    Forks Raised in Triples:
    Rear Tire Size:
    Aftermarket Triples/Offset:
    Fork Springs Wt:
    Fork Spring Brand:
    Fork Oil Amount:
    Fork Oil Brand & Weight:
    Fork Compression:
    Fork Rebound:
    Fork Valving:
    Shock Spring Wt:
    Shock Spring Brand:
    Shock Hi speed Compression:
    Shock Lo speed Compression:
    Shock Rebound:
    Shock Valving:
    Shock Oil:
    Race Sag:
    Preload:
    mikey526
    by mikey526 » Thu Aug 30, 2007 10:10 am
    Year: 2007
    Rider Weight: 110
    Rider Weight with Gear: 120?
    Riding Style (i.e. Desert, MX): MX
    Forks Raised in Triples: not currently
    Rear Tire Size: 90/100 -14 inch
    Aftermarket Triples/Offset: nope
    Fork Springs Wt:?
    Fork Spring Brand: stock
    Fork Oil Amount: stock
    Fork Oil Brand & Weight:stock& fish oil?
    Fork Compression: 17 clicks
    Fork Rebound:4 half turns
    Fork Valving: stock
    Shock Spring Wt: dunno
    Shock Spring Brand: stock
    Shock Hi speed Compression: I forget
    Shock Lo speed Compression: I forget
    Shock Rebound: I forget
    Shock Valving:stock
    Shock Oil: fish oil
    Race Sag: 3 1/4 in.
    Preload:stock
