Clutch
    riddler9
    by riddler9 » Tue Jun 25, 2013 7:05 am
    rvand12 wrote:I have a rekluse EXP in my '08 250R and would love to put one in my 150RB. I noticed your discussion about having one in your 150, but I dont see that rekluse lists a clutch for the 150. Did you find that a rekluse for 250 fits?
    http://www.crfsonly.com/catalog/product_info.php/cPath/181_185/products_id/2358
    Official Lurker
    motosicko
    by motosicko » Tue Jun 25, 2013 7:18 am
    Rekluse Z-Start Pro Mod. # RMS-810 is what I have. Looking on Rekluse website that # isn't listed anymore. CRF's Only has it listed though. Contact Ken and see if he can supply.
    http://www.crfsonly.com/catalog/advance ... &x=32&y=11
    "There are old racers
    and there are bold racers,
    by crfsonly » Wed Jun 26, 2013 5:24 pm
    yes, we do stock this and it's outstanding for all level of riders on the CRF150R.
  • Casey303
    by Casey303 » Sat Jun 29, 2013 4:10 pm
    So I finally took my bike back apart and fixed the gear shifter. Put it back together to try it out and everything works except the clutch lever. I thought that the z start pro let you still use the clutch. I also noticed I forgot one washer. Would one washer cause the clutch not to work?
    2009 CRF150RB
    riddler9
    by riddler9 » Sat Jun 29, 2013 7:35 pm
    Casey303 wrote:So I finally took my bike back apart and fixed the gear shifter. Put it back together to try it out and everything works except the clutch lever. I thought that the z start pro let you still use the clutch. I also noticed I forgot one washer. Would one washer cause the clutch not to work?
    If it was the thrust washer, yes.
    The clutch lever should be very week until the RPM's are up. Completely useless when the bike is off, not much if any resistance at idle, but only 1/2" of free play (fully functional) at 3000 RPM.
    Official Lurker
  • Casey303
    by Casey303 » Sat Jun 29, 2013 7:49 pm
    it was one of the washers that came off of the old clutch. I tried the clutch lever at different RPM's and it still didn't work.
    2009 CRF150RB
    riddler9
    by riddler9 » Sun Jun 30, 2013 6:28 pm
    see if the clutch gets tension at the transfer case. if so then your cable is stretched too far.
    you can check by taking the cable off the lever and pulling it with pliers.
    Official Lurker
  • Casey303
    by Casey303 » Sun Jun 30, 2013 6:37 pm
    I messed around with it today and found I didn't have it adjusted right. Get it adjusted and it works fine now. Thanks for all the help.
    2009 CRF150RB
    riddler9
    by riddler9 » Sun Jun 30, 2013 7:55 pm
    Cool, glad you got it figured out. Also a bit unnerving when you drop a bunch of cash on a new part and things go south.
    Official Lurker
  • Casey303
    by Casey303 » Thu Jul 04, 2013 8:27 pm
    So i took my bike on the trails today and it felt like when i get into the higher gears that it didn't have much power. Kind of like the clutch was slipping. Would this be because of bad friction plates?
    2009 CRF150RB
