help. bike runs FAST and well, but idles poorly/slowy/dies
    jtsurfs
    by jtsurfs » Sun May 09, 2010 11:17 am
    Based on the feedback others provided, you would probably be safe in installing the 48 pilot. And while you are at it you could check the valves to see if they need shimming.
  • rickyn613
    CRF150R valve shimming or valve replacement
    by rickyn613 » Sun May 09, 2010 3:56 pm
    Put in a 48 pilot, no luck. Disassembled and cleaned carb. MSR mixture screw 2-1/4 turns out. Seems like shimming is next. If I go with new valve and spring kit do I need to replace anything else? Valve job, Serdi maybe?
  • novocaine
    go straight to the valves
    by novocaine » Sun May 09, 2010 5:09 pm
    I wasted a TON of time on the carb on this, and it never made a difference. As soon as I fixed the valve clearance, the bike ran perfectly. I have a 48 pilot, but will put a 45 in sometime soon. It's just a hair rich.
    don't fool with anything else until your valves are in spec!!!!!
    Trevor
  • rickyn613
    by rickyn613 » Thu May 13, 2010 10:27 am
    Thanks. I will get them shimmed and see what it does. What do you think about replacing the valves/springs/seats/guides since I will be in there anyways? I bought the bike used, I'd say there's probably over 100 hours on it. I figure it couldn't hurt and then I would know what I'm working with.
    Thanks for the help guys.
    Ricky
  • llittler
    by llittler » Fri Sep 02, 2011 6:32 pm
    My daughter has a 2007 CRF150R. Bought it used a couple of weeks ago. This has been a really good post. Her bike was having the same problems. Adjusted the valve clearance today. Exhaust valves were okay. Inlet valves were way too tight. After the valve adjustment, ran great. Still had the idle problem. Replaced the stock 40 pilot with a 48, 2-1/4 turns out on the mixture screw. All problems solved!!!
  • LRussoPhoto
    by LRussoPhoto » Wed Feb 22, 2012 12:55 pm
    Well I have the same problem, i have tried everything mentioned in all the threads here and nothing is working. Only thing left from what a few people have mentioned is replacing the throttle plate seal. I will order that and see what happens. Any other ideas?
