Here's a list of the modifications and parts used to build the CRF450X project bike:
CRF's Only Project Bike
Bike: CRF450X
Type of Build: Offroad/Trail
Performance
JD Jetting Kit Red needle-4th clip, 170 Main, 48 Pilot, 1 1/2 turns
Boyesen Quickshot
Airbox Mods Removed snorkle, opened up side vents
Twin Air PowerFlow Kit Twin Air PowerFlow with Sealing Ring. Twin Air Powerflow Pre-Oiled Filter
Napalm Filter bolt
Exhaust White Brothers E2; Stock Header
CAM Hot Cams Stage 1
Zip Ty Hot Start Nut
CRF's Only Fuel Screw
Rekluse z-Start w/ Perch Adjuster
Applied Vent Kit
Applied Smog Kit
Five-10 Case Saver
Zip Ty Magnetic Drain Bolt
Suspension
Forks and Shock Valved and Spings RG3 valves, stock springs, DLC coated tubes, anodized shock body and other parts.
Controls
Pro Tapers RM-Lo
BRP Triple Clamp 22mm offset
BRP SUB Mount
Scotts Stabilizer
Hammerhead Shifter 10mm (stock length)
Foot Pegs White Brothers Tri-Pro Titanium Pegs
Kickstand Pro Moto Billet Kickstand
Handguards Fastway Performance with Black Shields Acerbis Rally Pro
Pro Taper Dual Compound Grips Half Waffle
Throttle Tube System Tech Racing Open End Throttle Tube
Braking
Wave Rotors Galfer floating wave rotors
Stainless lines Galfer
Fastway Cable Clip
Wheels/Tires
Excel Rims White Brothers built Talon/Excel Rims Rear (W/O Spacer) - 9lbs. 7 oz.
Talon Hubs Front Wheelset (W/O Spacer) - 6lbs. 14 oz.
Dunlop 756 Tires
T.M. Designs Slide-n-glide Black slide and chain guide
Zip-Ty Axle Blocks
Enduro Engineering Front Axle Pull
Protection
WC Skid Plate
WC Master Cylinder Guard
WC Rear Brake Guard
Scotts Rear Disc Protector
Unabiker radiator guards Black
Reklust Clutch Cover Black
Drivetrain
Chain Stock
Sprockets Dirt Tricks 13/51
Zip-Ty Axle Blocks
Electronics
Trail Tech Lynx Computer and Dashboard Custom fabricated sensor bracket
Rewound stator Baja Designs rewound stator
Baja Designs HID Headlight Baja Designs Tecate HID system
Hour Meter
Appearance
UFO White Plastics
Custom CRF's Only Graphics FLU Designs custom graphics
Works Connection Engine Plugs
Work Connection brake reservoir covers
Misc
IMS 3.2 G Tank - Black
Project 321 IMS Gas Cap
