2018 CRF450R starting issue
  • Hondasrock
    by Hondasrock » Mon Apr 05, 2021 12:31 pm
    Hey guys
    I have a brand new 2018 crf450 which I am having some trouble trying to get it started.
    When I press the start button I can here it prime the fuel pump but it will not try and turn the bike over.
    When I cross the starter relay (solonoid) the bike starts and runs perfectly. If I turn the bike off and quickly hit the start button it will start fine again. But if I wait more than 10 seconds the button becomes dead again.
    I have changed started button,
    Stop switch, solonoid, wiring harness, rectifier, throttle body, coil, fuel pump regulator and a different battery.
    Please someone shed some light on this before I burn her...😂
    Re: 2018 CRF450R starting issue
    by JimDirt » Tue Apr 06, 2021 7:20 pm
    The only thing I did not see you mention was the Clutch Switch , I am wondering if it is going bad , or has some kind of issue where it only gets intermittent contact ?? , I know on my 20 you have to have the clutch in to crank the engine ... What you could try is disconnect the clutch switch , and jump the 2 wires together (Bl/R-G), and see if it starts , if it does , the switch is the issue , you can either permanently bypass it , or replace it , but that is what I suspect is the issue ... :-k
    The Bl/R (Black/Red) wire goes to the Starter button and the Clutch switch
Users browsing this forum: Google [Bot] and 2 guests
