Help ! Wiring Diagram CRF250 L 17-20
  • Boa76
    by Boa76 » Fri Nov 22, 2019 3:33 am
    Hi,
    could anyone kindly help me?
    I'm looking for the wiring diagram for the CRF 250 L 2019.
    Thanks
    Re: Help ! Wiring Diagram CRF250 L 17-20
    by JimDirt » Fri Nov 22, 2019 9:46 pm
    This is a 2018 , but it should be the same , or at least close enough to help ....
  • Boa76
    by Boa76 » Mon Nov 25, 2019 1:36 am
    Hi,
    thanks for the welcome and thanks for the help !
    Do you have a service and repair manual ? if you could send me the PDF?
    I have the PDF of the model 2013. I haven't found the 2017-2019 PDF anywhere.
    thank you so much.
    by JimDirt » Mon Nov 25, 2019 10:12 am
    No , I do not ... I just found that doing a Google search for Wiring Diagrams for Honda 250L's ....... There is also a place called Manuals Lib https://www.manualslib.com/ , where you can pay and download , but you can also look at them (preview) the entire manual to make sure it has the info you need , but it will have a watermark to keep people from passing copied pages as their own till they pay for it .... I also know that you can buy them direct from Honda (go to any Honda Dealer) , they average around $50-$60 for a Factory Honda Service Manual *this is not a Clymer Manual , but a authentic Honda Factory Service Manual that ALL Honda Service Techs use**, which will give you everything related to doing any type of service on the bike from oil change to engine rebuild .... (Ken has Service Manuals here , but I did not see one for the 250L at all) ....
    by [email protected] » Sat Jan 25, 2020 12:47 am
    Electrical wiring diagram of crf250l 2013- 2017 & 2019 are similar the only difference is the additional of rev meter or tachometer which is not available of the previous model which has no revmeter or tachometer, the one that Mr. Jimbert send is the actual wiring diagram of the 2013 up to 2017 which has no tachometer. Myself I have the 2014 crf250l.
    by JimDirt » Sat Jan 25, 2020 8:40 am
    Great first post and thank you for contributing the differences for clarification .... ;)
