2005 450x Starter issue
  • Steezel182
    by Steezel182 » Tue Aug 27, 2019 2:02 pm
    The starter just does one single click when I push the button. It does not turn the bike over. Battery is fully charged.
    I was mid ride when this happened and it was working fine all weekend.
    I have no clue what happened, and info would really help!
    Re: 2005 450x Starter issue
    by JimDirt » Tue Aug 27, 2019 8:00 pm
    Have you had the bike since new ??? , and if so have you ever changed the starter brushes ??? , also , it is possible that the ground going to the block right behind the clutch actuator just above the front sprocket is loose , either the connector itself or the wire going into it , if you can tug on the wire and the wire moves in/out of the connector , then you need to re crimp it ..... Those would be my first guesses ..... 8-[ :-k
    02 CRF450R
    06 CRF450X
