by JimDirt » Tue Aug 14, 2018 9:06 am
From what i can see from their site , they mount from the lower subframe bolt location to the bottom side panel location , so in looking at complete plastics kits for 250X on Google, it shows 04-10 as the same plastic kit (UFO) , so i would guess that they should fit all those years because the bolt up seems to be the same or the plastics kit would specify 04-05 , then 06-10 , etc. which is the case for the 450R , they changed plastics kits from 02-04 , then 05-08 , usually because mounting locations change , with the 250X , i am not seeing that , you could try contacting their Tech Support and see if they can explain why the 04 is not included , but for just doing minimal research , i can't find why it would not fit
At the most you might have to redrill or offset a mounting hole to make it fit , as i can't see it being that far off , if at all , usually any frame changes were made to the frame spar (the large tube that goes under your shrouds , they sometimes change the angle) and the headstock was modified to accommodate the steering dampener in 08 , other than that , i don't recall much for changes announced in the 250X lineup over the years , same goes for the 450X , the only thing that was changed from 05-17 was the addition of the steering dampener and the smaller gas tank , needing different shrouds , that was it
Personally i would contact them directly either by phone or email/contact us form , and ask what specific reason they do not list the 04 , and IF it will still fit , or why they say it won't fit
