Welcome to the site !!
Are you talking about the bracket that holds the wiring down ?? , if so , i would personally put it on , as the wires could move and rub against the flywheel , and short out what you just replaced ... and yes you would have to remove the cover to do it , but it should not be a issue , as you can use sealant as long as you did not ruin the gasket (make sure you drain your oil first , or lay the bike on its right side with the bar/grip on a 5 gallong bucket or something , then you won't even have to drain the oil)
