SoCal450R wrote:I have a 06 450r i am running a 45 pilot jet from sea level to 4000
sbronco68 wrote:SoCal450R wrote:I have a 06 450r i am running a 45 pilot jet from sea level to 4000
Thanks for input. I put a #40 pilot jet in and still can’t get my bike to even run rough with the fuel screw turned all the way in. If I turn it all the way out it will almost die but not in. Any ideas?
Thanks Guys.......
sbronco68 wrote:I did replace the screw. Should I just replace the O ring to be safer? The O ring comes right out though if you pull the screw all the way out. I don't think its stuck.
nminus1 wrote:sbronco68 wrote:I did replace the screw. Should I just replace the O ring to be safer? The O ring comes right out though if you pull the screw all the way out. I don't think its stuck.
If its like the X screw(which it should be) there should be a washer too, my point was that if they hang up the screw can't go in all the way, therefore no ability to shut off the fuel in the circuit, to cause stalling. Try putting the old screw back in, perhaps the new screw is the cause? Gotta try every poss cause to get it straight
