Clearing those table tops
  • BillB
    by BillB » Fri Jan 05, 2007 11:50 am
    I can’t seam to clear the table tops I’m always coming up short. It feels like im caring enough speed everything feels right. My suspension is dialed & sprung for me. I watch other riders and it looks like they are not doing much different then I am. I ride at my local track (Ellsinore Mx Park)
    Any advise?
    I’m not preloading, but it doesn’t look like other riders are either. How do you do it.
    06 CRF 250X
    JD Jetting Kit
    Quick shot APC
    Air Box Mod
    White Bro E2 W R Header
    Works Skid Plate & Engine Guards
    Trial Tech Computer
    Smog block off kit
    Scotts Stabilizer
    Pro Tapers
    AVS F3 Levers
    S1 Hot Cam
  • _06_crf_250r
    by _06_crf_250r » Fri Jan 05, 2007 12:20 pm
    go faster
    06 crf 250r
    WB Carbon Pro
    AC subframe
    Pro Taper Contour
    Cycra powerflow fender
    Twin air filter
    works conn radiator braces
    works conn skid plate
    hammer head case saver
    renthal red 49tooth rear sprocket
    renthaul gold chain
    by 124 » Fri Jan 05, 2007 12:26 pm
    _06_crf_250r wrote:go faster
    What he said. Literally.
    dlpmx
    by dlpmx » Fri Jan 05, 2007 1:09 pm
    yep... when you think you've got it grab one more gear.
    Dale
    All mods listed in the Garage
  • DaveX
    by DaveX » Mon Jan 08, 2007 10:22 am
    If you are consistently landing around the same spot, you have a comfort level for the speed you are hitting it at. Follow another rider who is clearing it to get a feel for their speed. Also, don't ease up on the gas as you start the jump face.
    Dave
    05 450x
    Acerbis Rally II Hand Gaurds
    Flatland Rad Gaurds
    Applied Bar Clamps - black
    Pro Taper KX High Bars - black
    Pink wire mod / Applied Vent kit
    Fastway case saver
    JD kit 170/ red needle clip in middle
    Twin Air / air box mods
    Quickshot APC
  • Dust Devil
    by Dust Devil » Mon Jan 08, 2007 10:39 am
    The only tabletop I can clear is the one you put food on.
  • Hale701
    by Hale701 » Thu Jan 11, 2007 5:59 am
    Carry enough speed, then pin it all the way up the face of the jump. ;)
  • BillB
    by BillB » Thu Jan 11, 2007 5:23 pm
    Finally pegged it guys. Rode on Tuesday hit this jump over and over going a bit faster each time and finally clearing it. Feels good!
    Not bad for a 42 yr old fart!
    06 CRF 250X
    JD Jetting Kit
    Quick shot APC
    Air Box Mod
    Trial Tech Computer
    Smog block off kit
    Scotts Stabilizer
    Pro Tapers
    AVS F3 Levers
    S1 Hot Cam
  • DaveX
    by DaveX » Sat Jan 13, 2007 7:57 am
    Good Job :)
    Dave
    05 450x
    Flatland Rad Gaurds
    Fastway case saver
    Quickshot APC
  • Buckets
    by Buckets » Fri Feb 09, 2007 8:31 pm
    great job at clearing that jump! Im gonna be 42 in may and reading your post is a great sense of encouragement to us all who arent as motocross savy .and 40 or over
