No I have not Neil , but the thought has crossed my mind ..... let me know how it works ... if the shifting is not grabby and the clutch does not fade , then maybe I will try it ..... I use the clutch a lot , I don't abuse it , but I do use it for traction control and corner drive , etc. , so I am always feathering it ... but I try not to slip it for long periods .... for example , my 450X is on the original 06 plates ... my R has been on the same plates since 08 .... basket is finally starting to groove on the R , its got well over 600 hours on it ..... the X basket is getting a little grabby as well , so I will need to file the basket , and see how the plates measure up .... I pretty much use the oil I use in the engine , which at this time , is Amsoil Dirt 10-40 ....I have not tried ATF Type "F" in my 450. But I use it in the trials bike as it is recommended by the Gas Gas manufacture race team. Trials bikes take and get an incredible amount of clutch use and abuse compared to our dirt bikes.
I also use ATF "F" in my YZ250. It actually makes perfect sense. Automatic transmissions use the same style of wet clutches in an oil bath system.
Just food for thought for you. Next oil change I may give it a try in the transmission of my 450. I have utmost confidence it will work very well. I presently use Castrol GTX 20/50 or 10/40 with no issues ever.
Jim, you ever give ATF a try in the 450 ?
