starts only for a sec
    momuzik
    by momuzik » Mon Feb 12, 2018 10:45 am
    ok rebuilt engine and will only start for a second after pumping alot of gas, 5 throttle pumps, then dies immediately..any helpful suggestions?
    Re: starts only for a sec
    by Aussiecrf230 » Mon Feb 12, 2018 9:56 pm
    What year is yor bike?
    What jetting do you have?
    How old is the fuel?
    I am guessing it has a carby if so check the idle jet is not clogged and fuel screw is set correctly.
    momuzik
    by momuzik » Mon Feb 12, 2018 11:30 pm
    04 carb..ok i will check idle jet..thanks Ray..ps fuel maybe 2months old but I will put fresh fuel also..thank you
  • Bogdangavra
    by Bogdangavra » Thu Mar 01, 2018 6:50 am
    Mine does the same (2009 crf250r)when is cold (in winter) even if it's with choke on but after 2 or 3 startings it runs ok . If you rebuild the engine , maybe you must do valve adjustment , and check if you put the engine on signs.
