by JimDirt » Wed May 31, 2017 9:33 pm
Check the coil power wire and make sure it did not come unplugged , it could be that one of the connectors in a exposed position could have got moisture in it , so try blowing off all electrical connections with air , those would be the 2 most likely culprits , its just like washing a car engine and getting the distributor cap wet , it will start , then you shut it off soon and the condensation from the heat wets down the inside of the cap and no start....its possible that a connection is not sealed and has become grounded out or lost connection because of moisture , it SHOULD dry overnight and it should start tomorrow
Also , just in case , drain the float bowl , its possible somehow water got into the bowl or gas tank , , water will go straight to the bottom of the tank and get right into the bowl , it wont allow the gas to be sucked up into the jet and the bike wont start
