broken fork compression screw.
  • cmxi
    by cmxi » Wed Aug 12, 2015 2:51 pm
    Got a 2008 crf250r where the previous owner broken the compression screw in one og the fork legs.
    Is it possibe to strip the valve bolt assy from a 2006 crf250r
    and use The "top nut" to rebuild my 2008 fork leg??
    by JimDirt » Wed Aug 12, 2015 5:19 pm
    I have not looked at the 06 and 08 next to each other , but i am pretty sure you can swap them out with no issues , however you will have to use the valve stack from the 08 in the 06 cap assembly as the valving stack (amount and size shims)itself will be different
  • cmxi
    by cmxi » Thu Aug 13, 2015 3:19 am
    JimDirt wrote:I have not looked at the 06 and 08 next to each other , but i am pretty sure you can swap them out with no issues , however you will have to use the valve stack from the 08 in the 06 cap assembly as the valving stack (amount and size shims)itself will be different
    Great :D
    Yes they look very similar.
    Is there any good writeup anywere on how you dissasemble and assemble the valveunit to be able to use the 08 valve stack?
    by JimDirt » Thu Aug 13, 2015 9:53 am
    Take a look at this and see if it helps
    http://www.racetech.com/page/id/136
  • mossman77
    by mossman77 » Fri Aug 14, 2015 9:04 am
    Post deleted by creator.
    2007 CRF250X
    2004 CRF230F (sold)
  • cmxi
    by cmxi » Wed Sep 09, 2015 11:28 pm
    Just for info.
    Is the fork leg cap/ bolt assy from the CRF450R 2006 the same as a crf250r if i replace the valves with the one in the 250r bolt assy??
    They look similar and i found one for the correct money on ebay.
    by JimDirt » Thu Sep 10, 2015 5:18 pm
    It should be , but the valving will be different
    If you put your valving on it , and the Pressure Spring , then you should be fine
  • cmxi
    by cmxi » Fri Sep 11, 2015 12:13 am
    OUTSTANDING! :D
  • cmxi
    by cmxi » Mon Sep 21, 2015 12:38 pm
    Now it is fixed.
    you ned a special tool to remove the top nut but luckely the local dirtbike shop was kind enough to help with that part. Othewise a quite easy job.
    :D
    by JimDirt » Mon Sep 21, 2015 8:34 pm
    Glad to hear you got it fixed !! =D>
