by JimDirt » Tue Jan 28, 2014 10:31 pm
How long did it sit since the breakdown ?? , could be the pilot jet is clogged , is it popping a lot when you try to rev it mainly when you let off the gas ??
Have you checked the Hot Start at the carb , if it is stuck , it will lean out the motor
If it runs then dies , it could be the the float is stuck , as it sounds like its running out of gas
These are all things it "could" be , more detailed running and time frame info would help
