HELP
  • Spcwhite
    HELP
    by Spcwhite » Tue Feb 19, 2013 6:14 am
    I have a 2005 crf250r. I was having and i still am having very bad problems. I just had my valves replaced. I took my bike out for half of a day it just dyed as if my shims were bad. I have no clue on how to fix this issue so anything would help. I did take it to a shop to get replaced and this is what happened. i don't know if its the shop fault, because they have never gone out so fast. please help me with this issue.
    -Michael C. White
    Re: HELP
    by crfsonly » Tue Feb 19, 2013 1:59 pm
    welcome to CRF's Only. are the valve clearances known good? check and verify and report back. also, if you just had a shop do the work, you should work with them to make it right.
  • Spcwhite
    by Spcwhite » Fri Feb 22, 2013 5:48 am
    Thanks for the help. I took my bike back to the shop and they put a valve in wrong so when i was riding it the valve seat broke. So they are fixing there mistake. Thanks a lot.
    by crfsonly » Fri Feb 22, 2013 7:07 am
    "put a valve in the wrong way" hummm....frankly that is very hard to do. ;) now they are going to put in a new seat? hopefully they have the necessary expertise and equipment to replace a valve seat correctly. also, valve seats should be replaced in pairs if they are changing the material or the amount of material is significantly differnt in size.
  • Spcwhite
    by Spcwhite » Fri Feb 22, 2013 7:13 am
    They are replacing all my valves and valve seats for free because they did it wrong. Now i just have to wait and see if they are going to do it right this time. They said that they have all the tools to do it. So i guess we will find out.
