crfsonly wrote:when installing the AP update kit did you remove the check valve in the float bowl? if not, remove it. also, when you replaced the AP diaphragm was the original deteriorating? if so, you could have a piece of the rubber coating in the AP circuit obstructing/clogging it. check also the AP plunger rod. make sure it is installed correctly and function. do the same with the AP cam. report back.
crfsonly wrote:have you done anything with the leakjet? was it removed by chance? did you use the new AP cover that came with the AP update kit? Did you correctly install the new updated AP diaphragm?
crfsonly wrote:i would install the AP cover that came with the update kit and see if this resolves the issue. if not and the leak jet is in stalled correctly, the check valve is removed in the float bowl, the AP diaphragm and spring is installed correctly, plunger is correctly installed and functioning then you either have a problem drawing fuel into the AP from the float bowl or you have a clogged AP nozzle/circuit.
