Is it normal for the left intake valve to grow deposits while the right intake valve remains clean?
The reason I ask is that I did a top end job on my bike 55 hours ago. At that time the intakes were replaced with Ti OEM valves. I noted then that the left valve had deposits whereas the right valve was clean.
So I'm doing my winter maintenance and have the carb off and can look in and see deposits on the left valve and the right one is clean.
If this is common then I assume it is because the intake boot points more towards the right valve and it get's a more direct blast of mixture.
Previous owner ran 92 E10 whereas I run 92 non-ethanol.
Ken
