rear sprocket
  • rhiocrf230
    rear sprocket
    by rhiocrf230 » Mon Nov 19, 2012 9:46 am
    I have a 2007 250R Dropped the front tooth one size for trail bike type use also installed a recluse auto clutch. I need a little taller gearing for tight trails. What would be a good size rear sprocket. The current rear is stock. I need to reduce my first gear speed by about 30%. I do not want to go to large to interfere with the chain tensioner.
    Any suggestions would be great.
    Thanks....Rhio....
    by crfsonly » Mon Nov 19, 2012 4:25 pm
    this is a perfect situation to use our gearing calculator. you'll be able to compare what you currently have with what you considering. it will show you the percentage change between the two:
    http://crfsonly.com/howto/gearing/motor ... ulator.php
