by crfsonly » Fri Nov 16, 2012 12:14 pm
yes, they can be lapped. the question why would you do that to a brand new valve? lapping is an abrasive process used to "fix" valve seat cutting imperfections. it not only removes material from your valve seat but also your brand new valve! these imperfections occur because inferior cutting equipment is used (read: form tools used by hand or machine). we use a NEWEN single point cutter CNC valve seat machine that delivers perfect valve seats which are superior to any form and/or lapping process. don't settle for less as it will reduce your valve durability.
the stock exhaust valves are stainless steel. however, they are a two piece construction. the head and stem are friction welded. the stem is a lesser grade (read: less expensive) steel. i've never seen one come apart. i recommend Kibblewhite stainless on all fours with the KW high performance spring package. for the small increase in cost it just makes sense to do it with the same high quality valves and springs. just don't get talked into some off brand of stainless steel valves or mix matched springs to the valves. also, do not reuse retainers and cotters. these are wear items and we have seen them split causing a valve to drop. if you drop a valve it will cause very expensive damage.
that's good news on the filter. should be fine.
crfsonly on Sat Nov 17, 2012 11:51 am, edited 2 times in total.
