Fork Seals
  • redridr52
    Fork Seals
    by redridr52 » Fri Apr 18, 2008 10:38 am
    I noticed the other day that there was fork oil that had been running down the fork tube. I am assuming its a leaky fork seal. I have heard you can take a tearoff or a film negative and clean them out. Or is it too late and I should take them to a shop and get them changed for like $300.
  • dlx742
    by dlx742 » Fri Apr 18, 2008 7:40 pm
    go buy the seals and learn how to do them yourself. you'll end up saving major moneys
    by crfsonly » Sat Apr 19, 2008 6:56 pm
    try the film trick...it may just be some dirt under the seal. it won't hurt anything to try it. if it doesn't work then seal replace time.
  • Mikey350D
    by Mikey350D » Sat Apr 19, 2008 8:19 pm
    I use a bussiness card to clean seals
    (needs to be stiff and thin).
    But if your seals are elerly.. it's time.
    Of course your third option is to tell you friends you have those new self-lubricating forks!
  • redridr52
    by redridr52 » Sun Apr 20, 2008 1:46 pm
    So the loss of fork oil wont make a diffrence?
  • redridr52
    by redridr52 » Sun Apr 20, 2008 3:31 pm
    UPDATE: Tear-off $1, Money saved $300, learning how to fix your leaking for seals... priceless.
