Hard starting after crash
  • erer
    by erer » Mon Mar 24, 2008 12:46 pm
    Hello,
    I'm new to your forum but not to the CRF250's
    This forum seems very interesting!
    I have an '08 CRF250R. The bike runs great. Starts fine hot or cold but will not start after a crash or tip over! The hot start has little or no effect. The only way I've found to get it refired is to turn the gas off, lay the bike over to drain out the carb and then use the hot start. It will than refire in 2-3 kicks. The valves are spot on! I have owned an '04 and '06 and never had this much trouble with it starting after a crash!
    Any suggestions would be greatly appreciated.
  • heinracing
    by heinracing » Mon Mar 24, 2008 1:44 pm
    after i lay the bike down i pick it up turn the throttle 2-3 times and kick it over couple times no fire pull in hot start she should fire
    Sbbc250
    by Sbbc250 » Sat Apr 05, 2008 10:48 am
    well just dont fall, jk jk. um everytime i lay mine over and it smells like gas (flooded) i was told to hold the throttle wide open, thats always seemed to help me numerous times. If thats not your problem then idk.
    2005 CRF250R
    Hotrods stroker crankshaft
    Athena big bore 280
    Hotcam
    White Brothers carbon pro2.
    Powernow system
    boyesen quickshot
